Frame Drop with HD videos
Moe_P
I'm having this problem since the new update where I can't watch videos at 780p or higher resolution, the fps drops dramatically and it looks like I'm watching a stop motion video.
I'm using high performance, restarted the phone, cleared cache and still nothing. Anyone has suggestions?
Here are the detailed steps to play YouTube, Dailymotion, Vimeo and Other Online Video Streams in VLC for Android:
Copy the direct link to the video from your browser.
Switch to VLC for Android app.
Tap on Menu ☰
Go to Stream.
Long press under Enter network address and hit Paste.
op, what is the "new update" you are referring to? the may security patch or the latest Samsung UI firmware? highly doubt any OTA update is the source of your issue, lest there would be hundreds of people complaining.
OP. why dont you post up the videos you are having issues with so others with the same phone can test.
are you on wifi or cellular when you are testing these videos? did you do a speed test?
The Samsung firmware update, I didn't have these issues before but I'm not really sure that's the problem.
Basically happens with every youtube video, videos would load fine but where there's a lot of movement like action movies clips or basketball games closeups lag happens.
I tried both data and wifi to be sure and makes no difference and no I didn't do a speed test
Have you tried restarting your phone or tablet?
I did, didn't seem to have done anything
your issue is not going to be fixable over the internet. you may need to contact samsung.
without seeing your phone and what you have installed, it could be anything causing your issue.
if you have a way to record a video of your phone stuttering so those over the internet can visually SEE what you are talking about, that may be helpful.
there could be a rogue app that is not updated to the latest firmware or you could have some settings that were altered -- its just to big of a rabbit hole.
for grins I just tried some random videos using the VANCED version of youtube (3rd party) and all videos played fine. even in whatsapp conversations. I even used another 3rd party youtube viewer and no stuttering.
worse case a factory reset may be in your future.
edit: use your phones camera to record some random video around the house in the max frame rate and resolution. play it back using a couple of different video players. do you see any stuttering?
