A professional Battery Alarm, that can notify you when the battery has reached a certain percent (%).
For example, if you don't want the battery to keep charging after reaching 100%, you can set the alarm for 100%, and the alarm will notify you with a sound, that the battery has reached 100%.
Version: 3.0
- New design
- Performance improvements
- Bug fixes
- Add up to 10 alarms to the list
- You can now select the notification volume
- You can now select to disable 'background notification'
- The app main service now starts on device boot, so you won't have to open the alarm every time you turn on the device
If you have any ideas, please tell me! If you liked the app please rate it 5 stars in the playstore!
Version: 3.0
- New design
- Bug fixes
