[FREE with IAP] Kiosk Pro
Smiley88
pNiGIBTBcSUUiu2T7cNY9xawES_XNbBibZqqDQmewpRhR_8HS-0eV48LZj0PS8Mcjuw=h900
6eoO_RSJaYa-gD2abGTdM56T0JYPTJA-lUeQq_OsAjR3YrCjQwP9QvKfeMOpcVo_v7o=h900
IecteuDPF8rwiPfturd1tbljCRAfAuaRsm11zMWT4jSgKN_9IxQ9UQg6ZznnCpyFGt9y=h900
Description:
Kiosk Pro is a customized application launcher that will enable you or your organization to exhibit applications to the end user without compromising device security.
While in Kiosk Mode the end user can only run and access applications that are available to them. As an administrator you control which applications the end user will have access to. You can have one or many applications for the end user to run and to test.
While in Kiosk Mode the Notification Toolbar is disabled so that the user can not access incoming notifications or make changes to the device settings.
Recent application feature is also disabled so that the user can not launch recently launched applications.
As the administrator you can also disable Wifi and Bluetooth access. The user will not be able to turn them on.
Google Play: https://play.google.com/store/apps/details?id=com.toysoft.kioskpro
Price: Free with In App Purchase
