PhantomTrace
I got frustrated and began searching.
SOFT RESET/REBOOT ~ FIXED MY Android OS Bugs/Corruptions
Soft Reset/Reboot Does Not erase any of your data on your Phone.
Here's the steps.
Reboot G1.
if you power off your phone and hold the home (shaped like a house) and the end (red hangup button) for about 20 seconds you get a triangle with an exclamation point and a picture of the G1
after that if you open your keyboard and hold alt+L you'll get a menu that says:
Android system recovery utility E: Can't open /cach/recover/command
Home+Back reboot system now - (Soft Reboot)
Alt+L - Toggle log text display - (Toggles between the exclamation and menu options)
Alt+S - apply sdcard:update.zip - (Not brave enough yet)
Alt+W - Wipe data/factory reset - (What I chose, had to re-register, out of the box settings)
Here's the steps.
Reboot G1.
