froyo questions
Ok well i have an inredible and i was wondering a few things. Will the update just be sent right to my phone? How will i know when its sent? And when will it be sent? Thanks
It will prompt you at your notification bar that the download is ready. Note, checking the "update software" button will not let you get the update sooner, it is only in case you have received the notification and had to restart the phone for other reasons.
When they start rolling out, you will probably not see it at first. They are rolled out by the IMEI number. If memory serves, some people didn't see 2.1 updates for a couple days after other people did.
Well, the Nexus One hasn't even been updated yet. It is assumed that Droid's update will come after the N1. I would hope it would be soon though...
Either that, or root and install it now :)
