G1 Problem after flashing
Hi,
I have flashed my G1 with the Cyanogens 3.6.8.1 rom and found that my phone only rings once when someone calls. The call is still there it just stops ringing.
Have googled the problem but can't find a solution, anyone?
Hi,
Well I run his 3.9.8 build and have tested and used most of them and never had that issue so I would have to ask if 1 you were rooted 2 if you switched from someone else's build to his build 3 if you did switch did you wipe ALT+W before installing?
