Hi, in an attempt to unlock Wifi Tethering capability on my phone, I installed [G900F]CyanogenMod 14.0-20161020-UNOFFICIAL-klte, and now I'm unable to make phone calls or use SMS/MMS.
Is there anything I can try to get service back?
I've tried installing a new modem with no success, using Odin, FlashFire, Terminal Server. I'm not confident I was doing it correctly though, or even if I was using the correct modem files.
I was able to root the phone with Stock firmware, but Mobile Hotspot/Wifi Tether wasn't built-in, and I had no success with any of the apps... FoxFi, Wifi Tether Router, Barnacle Wifi.
Some more information on the phone:
It's the StraightTalk variant made for TotalWireless MVNO. The phone's Stock firmware said it was the S902L Samsung S5 variant, but under the battery FCC ID of the device is actually just a G900V. I took it to the Verizon MVNO PagePlus and they were able to activate the phone, and everything was working perfect, until installing CM14.0.
A roadblock I found out, that might be the root of some of the problems, is the phone may not have the ability to unlock the bootloader, possibly limiting some modding methods. When looking at /sys/block/mmcblk0/device/cid, it starts with 11, designating a Toshiba eMMC chip.
I'll take any suggestions, or alternatives... I don't mind using the stock firmware or any other Roms. The main feature I'd like to have is the ability to use Wifi Tether and the basics, make calls, send sms.
Thank you.
Thank you.
