Hello !
Here is the problem :
When connecting on my home router the connection process is all fine (it gets connected flawlessly) but when I try to use any app or internet it mainly says that the web page is not avalible, to add more to it when I got the phone a week ago i connected to my network and it worked. Also public hotspots work fine (tryed about 4 of them) and I have a laptop that connects to my router and it works fine. I have been searching the forums and many websites for 2 days now trying to find the solution, here are the things that i tryed :
reseting the phone, reseting the software
reseting the router, reseting it to factory settings
changing the channels in router settings
removing any kind of protection in router settings
checking if the phone is getting the right IP adress - it is
allowing the MAC adress in access control of the router
That would be about it, I hope that someone did have the same problem and that they solved it
If needed I will provide any information that is necessary to solve this problem! Thank You !
