Galaxy Ace internal memory bug? PLEASE HELP!
my galaxy ace has 26 mb left on the manage app menu and there is a icon for internal storage full but it doesnt show at the notifications? but when i check the internal phone storage,it says it has 154 mb available space.
my phone is also rooted and has Su on it.
please,what should i do and what are the steps?
please help.
Here is the Instructions To Clear/Clean Internal Memory of Android Phones
1. Dial * # 9900 #
2. Select/Click "Copy to SD"..
( this will copy all dump files from internal to SD Card, because all dump files consumes large amount of internal memory) Note: Only Select the "Copy to SD" Be carefull...
And see the MAGGGGIIIICCCCCC internal MEMORY FREE..
. -----You May Experiment to Another Android Phones Using this Instructions------------------By: Donald IT/Support Doha Qatar...Mabuhay Pilipinas.!!!!...
And I HOPE IT HELPS A LOT....!!!!
First clean catch of application like fb,internet,market...
then delete unnecessary application as application in SD also occupy some space in internal storage..so only deleting application that are in phone may not make big difference..
go to setting->application-> all application
total of internal memory used is sum of memory used by all application irrespective of application is on phone memory or SD card
thank you.it helped alot. :D
another question. how can i remove the icon from the notification bar?
it looks like a sd card with a exclamation point.
how can i remove that from my notification bar?
please reply thank you.
1. Dial * # 9900 #
Excellent!! Thanx for the tip, very useful! Gained nearly 10mb's on internal memory! :)
Just one question, it has added these 10mb's to the SD Card in 3 new folders called "dumpstate_app_anr.log/error.log/native.log" Can I delete these 3 folders now too, therefore deleting the dumped stuff & regaining the 10mb's back on my SD Card?? :confused: Is this safe?? Thanx. Graham - London
