Root Galaxy ace wifi not working due to rooting
i am new to rooting and all and when i rooted my phone it went well.
mainly i did it to move apps from internal storage but saw that it was a long process and didn't understood it.............so i unrooted . but i made a backup from titanium backup............then this problem came when my wifi isn't working and i thought that nothing is working so i did a factory reset.
that too didn't help and now i'm stuck.......even the cwm recovery isn't getting removed and i tried too root so that i can use titanium backup but when i do so it doesn't root and the last line it says installation aborted..
PLEASE HELP THIS POOR CHILD
Simply rooting the phone cannot disrupt your wifi, and unrooting will not remove cwm from your device. You should either flash stock recovery on your phone or flash the entire stock firmware from Odin to recover stock recovery.
For your wifi problem, you have not told anything that would tell us what is wrong with your wifi, what happens when you turn it on? why do you think its not working? Explain your problem a bit only then will be able to help you.
Just saying its not working won't give us an insight into your phone mate.:p
