Galaxy Mini wont turn on (wont turn on into download or recovery)
hi there - i rooted my galaxy mini with universal root and worked fine, then i flashed CWM with rom manager and accidently hit the wrong phone and couldn't stop it, so i thought oh well, probley still will work. so i turned it off and switched it bak on but it wont even turn on or bring up the logo or anything, and it wont go into recovery of download, is there absaloutly anything that i can do?
:mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad
Theres is nothing you can do!
Your only solution is to go to the mobile shop where you bought it!!
You bricked your device... You should have never used rom manager in the first place without doing some research on it.
Well, anyway, your best bet is to try flashing a rom via Odin --if your device is detected.
If it is not detected in Odin, then try unbricking tutorial posted here at all things root forum and try your luck.
Lastly, your final destination is to visit Samsung center and claim your warranty. :)
