kevinkevinkevin
Writer
This resource created by Phandroid.com Contributing Editor Kevin Krause as part of an Official Series of beginner tutorials for Android Forums.
Taking a screenshot on the Galaxy Note 4 is similar but different to the process on other Android phones. To do so, you must press the power on/off/standby button simultaneously with the home button located below the display. Hold briefly and the screen will flash, indicating that you have captured whatever image was displayed.
Here is a demonstration using the Galaxy S5, which utilizes an identical process:
But the Note 4 has a trick up it's sleeve that it shares with the Galaxy S and certain other Samsung phones. You can take a screenshot using a palm-swiping gesture once the feature is enabled from the settings menu. To do so:
- From the Settings menu, navigate to "Motions and gestures" under the "Motions and Controls" header
- Tap "Palm swipe to capture"
- Enable palm swipe to capture by switching the toggle at the top of the menu to "On"
