Lithium Ion batteries have no memory, therefore it is unnecessary to drain it completely before recharging it. In fact, a good way to damage the battery is to discharge it completely, although cellphones generally shut off before that happens.
Charging Lithium-Ion Batteries
Draining the battery to empty will only decrease it life. Just use it and charge when you sleep. The average user will find that the battery will last a good day or more. If not you might need to top off your charge if you can keep your hand off of it.
Main thing is to not worry. Just use you phone and enjoy it.
