Help galaxy s3 bezel seems to be seperating from phone.
hello,
does anyone else have this problem.i seem to have a nice size gap between my bezel and screen..at first i noticed some gunky looking stuff and figured dust or something must be building up so i go to wipe it and it war thicker.it looks like old adhesive.so a peice came out and it is def some sort of glue or adhesive.
here is a pic.
I looked at mine and do not have any gap between the glass and the bezel. If I were you I would return it. It will get worse over time.
i called the store i purchased it from.and they said they will do a one time order and have it sent to my house.does anyone have any experiaence with this threw tmobile.will i get a new one or a refurb or what?they said it might only be the unit.no case,battery or sim.and i will need to use mine.
