Help Galaxy S3 i747 car bluetooth issue
rs1985
I am struggling with this
the car do not connect automatically
when I try to make it work
i have to forget it and than go back
but when I start the car again
same thing happens
it won't connect it to the car
it keep on saying connection fail
after hearing may people with issues regarding 4.0 (like the ICS on the SGS2), I worried my Parrot 3200 would have problems. So far, it has worked fine. But, I have friends who are service managers at Toyota and Ford, both say that lots of people are coming in with connection issues and newly updated ICS phones (or new ICS models).
I dont know much about this problem, but I will say that the difference between my BT setup and something like my brothers Ford Sync system, he's connecting with audio and tele... and it seems like there's a conflict. Whereas, I'm simply connecting to tele only (tele audio via headset profile) and not using it for music at all... as my older Parrot doesnt even have that feature.
same thing happens
I have a similar problem with my International S3. It's extremely frustrating and there doesn't seem to be a fix at least none that I've found.
I'm currently on a Omega v7 ROM with Siyah Kernel.
Mine works well with My Lincoln Touch system in my vehicle. Better than my S2 did. The one thing that does cause issues is when I plug my phone into usb for charging. It starts to play all my ringtones through the speakers of the vehicle until I change the source to something else.
