Help Galaxy S3 wifi connection problems
solved !!! solved !!! solved !!!
1. Go to your router settings.
2. In wireless, go to "network mode"
3. In network mode, there were 6 modes given:
802.11 B/G/N mixed mode
802.11 B/G mixed mode
802.11 G/N mixed mode
802.11 B only
802.11 G only
802.11 N only
4. Select " 802.11 B only"
5. Save and exit.
Earlier, my router was in mixed mode (B/G/N) and there was error in connecting. The wi-fi singal was of pull power, but it was showing "poor connection, network disabled". After changing the network mode to "B" only, my Galaxy S3 connected seamlessly as before.
i dont know the reason, why my s3 was working initially when router was in mixed mode, why it stopped suddenly? now i am happy...atlast working... - Try this step and if working., spread the news and help others - Regards..Vijay
Hello,
Thanks a lot for your tip, I changed it to mode B, restarted router, and it worked (tested on Galaxy S3 Mini). I wanted just to add that I put back the original mode, which was b+g+n, and wifi kept connecting normally. The mode B is simple, so more stable, but is slower and less secure... http://superuser.com/questions/6062...f-b-g-and-n-wifi-standards-on-the-same-speeds
