A
Android Question
Guest
Hello, I have a galaxy S4 and awhile ago i noticed that the nfc service kept draining battey from 25 to 37%. (I have Finnish as my phones language) but I guess i pressed the "force stop" or similar button from the nfc settings and I thought that would solve my problem. Well, it did not (still drains battery the same amount all the time). Now I can't turn nfc On anymore and from the menu it shows that it's neither On or Off (pic link at the bottom)* I have done the factory settings reset once and I also got a new battery since I found out that the Nfc is located in the battery. Neither of those worked. Battery drain from nfc still sometimes nearly 40% ... I will put a couple more photos if it will give you a better view of the situation. I guess the problem has something to do with the force stop thing... I have tried to do it again a couple of times and no results..
* http://tinypic.com/view.php?pic=14jattv&s=8#.VN0F3fmsUpU
http://tinypic.com/view.php?pic=1z5q6ax&s=8#.VN0FdfmsUpU
http://tinypic.com/view.php?pic=a2u2rq&s=8#.VN0GFvmsUpU
