Help Galaxy S6 - Edge / Tasker no mobile data toggle
Hi
When I use tasker to turn on/off mobile data, it simply does not work .
Any suggestions, I checked trigger (app) to see if I could use it in combo with Tasker, but also no toggle there, it's not even available in trigger.
I have Galaxy s6 edge on 5.1.1 .
Kind regards Kevin
Welcome to Android Forums.
If you select the Mobile Data action in Tasker there is a popup that says ...
"Mobile Data is not available in Android 5.0+, try the Secure Settings plugin and a rooted device."
When the popup disappears there is a Mobile Data action added to the task but it apparently does nothing (unless you ran the task on a pre 5.0 machine).
... Thom
