A AMMA Lurker Jul 25, 2016 #1 How do i view applications that I've moved onto external sd card galaxy 7 edge !!? thanks AMMA
A AMMA Lurker Jul 28, 2016 #2 Thank a lot, but the applications that I transferred from the internal storage doesn't appear.
A AMMA Lurker Jul 28, 2016 #4 With a microSD card installed, launch the Settings app. Find and select Storage from the list of options. Tap on Internal storage. Select Apps. Locate the app you'd like to move, and tap on it. Under the "Storage Used" section, tap on the Change button and select SD Card
chanchan05 The Doctor Jul 28, 2016 #5 And the apps don't work? They should still be in your app drawer working fine. What are you trying to view?
LightspeeD007 Newbie Jan 13, 2017 #6 funny they asking questions without wanting answers to em. some people huh
