Help Galaxy S7 has water damage after 5 seconds in pool
Last night around 7pm I put my phone in 1 foot of water for roughly 5 seconds. After the phone was in water I proceeded to dry it with a towel. Due to the s7 being advertised as water resistant in 5 feet of water for up to 30 minutes I assumed it would be fine. This was not the case, the phone now has problems with charging, random black screens, and will not charge past 70%. Any recommendations? Samsung has told me it will take then 15 days to take care of the issue which seems like an awfully long time considering I paid $700 for the phone.
In a perfect world,your phone shoulda been no worse for the wear.
However,Samsung has covered their arse with the following legalese:
(See Page5)
http://downloadcenter.samsung.com/c...G930_UM_EU_Marshmallow_Eng_Rev.1.0_160219.pdf
Maintaining water and dust resistance Your device supports water- and dust-resistance. Follow these tips carefully to maintain the water- and dust-resistance of your device. Failure to do so may result in damage to your device. • Do not immerse the device in water deeper than 1.5 m and keep it submerged for more than 30 minutes. • Do not expose the device to water moving with force, such as running water from taps, ocean waves, or waterfalls. • If the device is exposed to clean water, dry it thoroughly with a clean, soft cloth. If the device is exposed to other liquids, rinse it with clean water and dry it thoroughly with a clean, soft cloth. If you do not follow these instructions, the device’s performance and appearance may be affected. • If the device has been immersed in water or the microphone, speaker, or receiver is wet, sound may not be heard clearly during a call. Wipe the device with a dry cloth or dry it thoroughly before using it. • The touchscreen and other features may not work properly if the device is used in water. • Your device has been tested in a controlled environment and certified to be waterand dust-resistant in specific situations (meets requirements of classification IP68 as described by the international standard IEC 60529-Degrees of Protection provided by Enclosures [IP Code]; test conditions: 15-35°C, 86-106 kPa, 1.5 metre, 30 minutes). Despite this classification, it is still possible for your device to be damaged in certain situations.
With that said,I'd take 'em up on their offer to take care of the issue & get a Lifeproof case for it if this type of use is gonna be a normal part of your phone use experience:
http://www.lifeproof.com/en-us/galaxy-s7/fre-for-galaxy-s7/lpfr-sam-gs7.html
Considering how heavily Samsung is advertising it with the water resistance in mind, it should be able to handle water better than the reports? I'm too scared to really try it myself.
It's only water resistant up to 3 feet for 30 minutes, it states that in the specs. I just got a lifeproof case for mine that effectively doubles the protection, and it works very well. I like to take pics underwater and they look great.
Update the phone since opens VR at random times , apps that previously did not crash have started crashing, phone lags regularly now, and it doesn't connect to 4g lte in areas where it previously did.
Just out of curiosity, which case are you using?
How can Samsung slap an ip8 rating on the S7 (one step better than the S5) and not back it up? A foot of water for 5 seconds is a far cry from 3 feet for 30 minutes! Why bother with the expense of adding the technology and touting it if they can't back it up? False advertisement? And I was SO wanting to waste a few bottles of champagne by pouring it over my new phone ;)
STUPID, stupid and extra stupid for admitting you did that on purpose! :rolleyes:
