To insert a MicroSD card into the Galaxy S7, first you'll need to remove the SIM tray on the top of the phone. Here is the process in an animated GIF from Samsung:
Step-by-Step instructions:
Some additional tips:
- Insert the ejection pin into the hole on the tray to loosen the tray. Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
- Pull out the tray gently from the tray slot. When you remove the tray from the device, the mobile data connection will be disabled.
- Place a memory card on the tray 2 with the gold-coloured contacts facing downwards.
- Gently press the memory card into the tray to secure it.
- Insert the tray back into the tray slot.
- Your device accepts memory cards with maximum capacities of 200 GB. Depending on the memory card manufacturer and type, some memory cards may not be compatible with your device.
- Some memory cards may not be fully compatible with the device. Using an incompatible card may damage the device or the memory card, or corrupt the data stored in it.
- Use caution to insert the memory card right-side up.
- The device supports the FAT and the exFAT file systems for memory cards. When inserting a card formatted in a different file system, the device asks to reformat the memory card.
- Frequent writing and erasing of data shortens the lifespan of memory cards.
- When inserting a memory card into the device, the memory card's file directory appears in the My Files —, SD card folder.
