Galaxy S8: How to set up Do Not Disturb
The Galaxy S8 has a feature called “Do Not Disturb” that will quiet all distractions during a specific time period. If you value your quiet time, this is something you should set up.
  1. Go to Settings > Sounds and vibration
  2. Tap on Do not disturb
  3. Toggle the switch on OR
  4. Create a schedule with days and times
There is an option to allow exceptions. If you don’t allow any exceptions the phone will be completely silent (not even alarms will break through). Your best bet is to add exceptions for alarms, certain numbers, and important apps.
