Galaxy S8 Plus: How to organize quick settings
The notification panel is full of toggles called "Quick Settings." By default, this area can seem a bit messy. You should organize it and put your favorites at the top.
  1. Pull down on the notification shade
  2. Pull down again to reveal all the Quick Settings
  3. Tap the three-dot menu icon and select Button order
  4. Drag and drop icons to rearrange
  5. Move icons to the bottom to remove from Quick Settings
  6. Tap the back button when finished
