If you want to keep a close eye on battery life you should show the exact percentage in the status bar. This gives you more detailed info than the battery icon can.
- Go to Settings > Device maintenance
- Tap the Battery button
- Select the menu icon
- Tap Advanced settings
- Toggle on Percentage on status bar
