Galaxy S8 Plus: How to use edge screen
All of the Galaxy S8 models have curved displays, including the Galaxy S8+. That means you get to use the Edge Screen features. There's a lot you can do with it.
Shortcuts to apps & people
  1. Swipe the Edge screen handle from the edge of the screen
  2. Swipe left or right on the panel until you see People or Apps
  3. Tap the + icon to add an app or contact
  4. To remove an app or contact, long press and drag to the trash
  5. Drag the apps or contacts to re-order the list
You can add more panels by going to Settings > Display > Edge screen. Select Edge panels.
Edge Lighting
You can have the edge of the display light up when you receive notifications.
  1. Go to Settings > Display
  2. Select Edge screen
  3. Toggle on Edge lighting
  4. Tap Edge lighting and choose when to show it
