Accessories Galaxy S8 VRS Design High Pro Shield case
GamerCore
The VRS Design High Pro Shield case for the Galaxy S8 and S8+ features a unique, brushed finish on the back. It's complimented by a hard plastic bumper that wraps around the entire frame of the device, giving it a splash of color.
The case is made from TPU, which means it's tough, flexible, and provides adequate drop protection thanks to air pockets in the four corners. There's a raised lip on the top and bottom for a "lay-on-table" design, providing enough protection for the screen when laying face down on flat surfaces.
The High Pro Shield comes in five different colors and if you're looking to pick one up for yourself, you can buy them direct from VRS Design using the link below.
Buy on VRSDesign.com
