No, the SIM does not use the SD slot. There are 2 sizes for most cell phones right now, the I9300 uses the micro size, but you can cut the larger size to fit. I also will say, not to look for just any unlocked S3, it needs to be a model number that uses the frequencies that AT&T uses if you want to use an AT&T network Straight Talk sim in it.
