Gameboy for Motorola Atrix???
Static_P7
I apologize if this has already been covered but can someone Give me a walk through on how to install the gameboy emulator and play pokemon on my Motorola Atrix please?
Been trying to figure this out for 3 days.
Thanks in advance for the help!
Download gameboid from your phone through the site below. Make sure you check allow unkown sources on your phone
https://slideme.org/user/3168/applications/3168
Install Gameboid but don't open yet.
Through your phone google gba BIOS. Download the gba BIOS file through you phone. This file should end up in sdcard/download on your phone if your using internal memory just look for "download" folder regardless.
Now open gameboid it will ask for BIOS and should show the contents of your SD card or phone memory. Look for the "downloads" folder click it then find the gba BIOS file you just downloaded. Click it and it should read it as having BIOS set.
Now it should be asking for a rom to load which are the games. If you dont have roms use your phone you can download them with your phone from some sites like romhustler etc (google it). When you download a rom (game) you want from a website they should end up in the download folder too. In gameboid click the rom you want to play and it should load up and work. It should also play any gba rom from now just by clicking the name of rom you want to play. Since the Bios has been set and it only has to be set once which you should have already done.
If you use Romfetcher app from Market to get roms fast and easy. I think when you download the roms they probably would end up in a folder called "roms" instead of "downloads." Romfetcher may have an option to download the bios too. I use an app thats not on market any more but still works and it included the bios as well as a few app of the same kind in the past.
If you was just looking for help with original gameboy and not gba. Use the gbcoid app from the slideme link I provided. Skip bios part since its only needed for gameboid. Then go straight to getting and loading roms part.
