GBA Emulator issue
kalas1973
Hey, I had a bit of a problem with my gameboid emulator. I was up all night playing games on it, I saved them, and now it says I have to buy the app. Okay, no problem, I thought, but my dad (who pays my bill) says he doesn't want me to buy it. Is there some kind of workaround so that I can either access the games, or buy the app without my dad knowing?
if you purchase the app, it doesn't go on the bill. you purchase with a debit or credit card. and to my knowledge, unless the dev changed how the free version works, you should have no issues continuing to play for free. your bios, saves, and games are stored on your sd card, so if you want to give it a try, uninstall and reinstall.
okay, how do I enter in my own credit card, then? I assume the default is whatever pays the bill, and I can't find the option on market...
there is no default, and to my knowledge you can't even opt to put the cost of an app from the market on your bill. when you go to the paid app just tap it and go to purchase and it will have you set up an account with whatever credit or debit card you would like to use.
