Gear S3 "do not disturb" trigger from calendar?
Orddu
I've gone from a Pebble Time to a Gear S3, which is by far a closer fit to the Pebble than any of the Wear ones I tried.
The one thing I miss is that the Pebble could be told to follow the calendar and set DND (i.e. no vibrating) for calls or messages during a live calendar appointment. I work one-to-one with people in a silent room, and I don't want it going BRRPBRRPBRRP at a critical moment! I know I could switch it manually, but that would be several times a day and I'll just forget.
At present I've compromised by using the DND scheduler to turn off notifications from 10.30am to 7.30pm every day, but it's not ideal.
I've looked through the app store and can't fine anything which seems to do this. Any ideas, anyone, or would some dear soul like to write something that does it? :-)
I've looked through the app store and can't fine anything which seems to do this. Any ideas, anyone, or would some dear soul like to write something that does it? :)
There are a few class scheduling apps that will help in some shape form or fashion but I would use Google Assistant a go for starters to see if it succeed your expectations.
