Gemini read aloud doesn't work
I just took Google Androids suggestion and switch from OK Google to gemini. Now it cannot read aloud what's clearly on my screen a Chrome web page. But OK Google did it just fine. Anybody have the same experience with gemini?
To switch back to "OK Google" (Google Assistant) instead of Gemini, open your Google app settings, navigate to "Google Assistant," then under "Digital Assistants from Google," select "Google Assistant" to choose it as your primary digital assistant; this will allow you to use "OK Google" to activate the traditional Google Assistant instead of Gemini.
Key steps:
Open the Google app, Tap your profile picture in the top right corner, Go to "Settings", Select "Google Assistant", and Under "Digital Assistants from Google," choose "Google Assistant".
