GENIATECH Android tv box FAQ
Status
Not open for further replies.
Unforgiven
...eschew obfuscation...
Administrator
Since this is a new FAQ guide for the Geniatech Box, we need your help to populate it and keep it organized with the best and most relevant information. Please contact (by PM) your favorite Guide, or drop us a note in the private chat section if you have any good information to contribute, update, or correct in the FAQ's. Alternatively, hit the
button and ask a Mod to bring it to our attention.
Thanks for your help!
Special thanks goes out to
vikidroid for helping us to put this together.
-video guides, tests and previews for geniatech devices
Hi all, I made these two following videoguides to show how to get more apps from Android Market.
I had already explained, step by step, how to do here: http://androidforums.com/google-tv/408166-geniatech-enjoy-tv-20.html#post3990926
...but I thought that it could be more interesting to show, visually, all passages.
The first videoguide shows how to get those apps (as for example: facebook and tweetdeck)
missing due to lack of right permissions: Full Access to Android Market: permissions trick (Geniatech ATV1000) - YouTube
This is the link to folder, that I called "full_permissions", which gathers many more
permissions than original: full_permissions.zip
The second videoguide shows how to get those apps (as for example wealth tv)
missing due to a not performing fingerprint: Full Access to Android Market: fingerprint trick (Geniatech ATV1000) - YouTube
This is fingerprint to use:
ro.build.fingerprint=verizon_wwe/htc_mecha/mecha:2.3.4/GRJ22/206244.9:user/release-keys
Please, any reply inside main thread "Geniatech Enjoy Tv"
-permissions and fingerprint fix as well as problems with tweetdeck and some google apps
Hi retspan, ziczac, cajen and everyone...
I updated my firmware to latest 20120111 release and after various trials,
I have found the solution for a correct upgrade of permissions folder and
fingerprint, also on ATV1000 with 2.3.4 release.
Pratically, using the same "permissions" folder and fingerprint line, we must
follow a different procedure...
First of all we must go to ---> Settings ---> Applications ---> Manage applications
---> All ---> GoogleServicesFramework ---> Clear data and Force stop (back) --->
Market ---> Clear cache and Force stop ---> (back home)
Then we enter Rootexplorer ---> go to: /mnt/sda/sda1 and copy "full_permissions" folder
from pendrive (long press on left click) ---> go back to: /system/etc ---> click on "Mount R/W"
---> rename original "permissions" folder (for example to: permissions_backup) --->
paste "full_permissions" and rename it to "permissions" ---> give same attributes of original folder
---> (back to the root)
Now we edit build.prop and change original fingerprint line:
so, we go to: /system ---> we open build.prop using text editor (long left click on file)
---> delete original fingerprint line:
ro.build.fingerprint=MBX/stvm3/stvm3:2.3.4/20111212/20111212.163332:user/test-keys
and insert new fingerprint line:
(automatically, a backup copy of build.prop will be created)
Remaining in: /system ---> we enter "app" folder and (temporarily) uninstall GoogleServicesFramework.apk
(we can do that renaming it, as for example, to: GoogleServicesFramework.apk1 ...if we check and go to:
Settings ---> Applications ---> Manage applications ---> All
we don't find the application)
then rename again: GoogleServicesFramework.apk1 to GoogleServicesFramework.apk ---> (back home)
(This last passage makes the difference and resolves all difficulties with internet connection)
At this point, we reboot device, enter Market, insert our Google account and a more
complete Market will be there for us!!
So we will find missing apps like facebook, tweetdeck and more...
Referring to everyone would try this method, I can say that I'm not responsable for everything could happen
(I suggest a previous backup of data and apps)
In the next days, I will make a video guide, to show visually all passages
Edit:
For more working apps, you must add this missing file: com.google.android.maps.jar
to "framework" folder in: /system/framework and change its permissions to rw-r-r
For more compatibility, I suggest to use this fingerprint line:
(if you have a 2.2 "froyo" firmware release)
and this fingerprint line:
ro.build.fingerprint=google/passion/passion:2.3.4/GRJ22/121341:user/release-keys
(if you have a 2.3 "gingerbread" firmware release)
More fingerprint lines here: Google Nexus One - OpenGL ES performance and system information
(go to --> "Browse the GLBenchmark"--> choose your device --> (ok) --> "System Information" -->
scroll down to --> "android.os.Build.Fingerprint" --> choose your fingerprint line to test)
If your market release is 3.4.4 or superior, you must remove this file: android.hardware.nfc.xml
from "permissions" folder in: /system/etc
-android market - v1.8, v2.3 and v3.4
Hi vikidroid, I don't know the reason, but surely you should solve giving a complete wipe and reinstalling again your firmware.
I suggest not to add marketupdater.apk in: /system/app (it will cause the update to google play).
In the meantime, continuing my tests, I modified this update file: update_google-play_3.4.6.zip
and I created, just for you and all users, three different update.zip packages:
update_full-access-to-market.zip:
update_market_1.82.zip:
update_market_2.3.6.zip:
which, easily and quickly (in recovery mode), allow us to install different markets (1.82 or 2.3.6)
and give us access to a more complete market.
So, if you want, you can also try to upgrade using update_market_2.3.6.zip
and update_full-access-to-market.zip.
Rename them to update.img and install as usual.
Let me know...
Edit:
These packages are specific for 2.3.4 Gingerbread releases, don't use them for ICS.
*(If Google Play Store is your inbuilt market, then, after the update to 1.82 or 2.3.6, you must go to:
Settings --> Applications --> Manage applications --> All --> Google Play Store and click:
Clear data & cache --> Force stop --> Uninstall updates)
-misc links, most discused topics
-supported 3g sticks
Supported 3G modems (all EnjoyTV images)
E1750 Huawei WCDMA Usb Dongle - verified
E1820 Huawei WCDMA Usb Dongle
E173-u Huawei WCDMA Usb Dongle
EC1261 Huawei CDMA2000 Usb Dongle
EC122 Huawei CDMA2000 Usb Dongle
E220 Huawei WCDMA Usb Dongle - verified
E173-s Huawei WCDMA Usb Dongle
MF633 ZTE WCDMA Usb Dongle
MF110 ZTE WCDMA Usb Dongle
MF190 ZTE WCDMA Usb Dongle - verified
MF637U ZTE WCDMA Usb Dongle
-official geniatech box user manual
http://files.prom.ua/100576_oid_tv_box_user_manual_1.3.pdf
-rom update instructions, supported 3g sticks and webcams
http://www.geniatech.com/news/newsletter/Geniatech-Android-2.3-upgrading-instruction.pdf
-how to modify and make custom rom (android v2.x.x to 4.x.x)
Hi vikidroid, skull and all guys of forum...
I have good...great news!!:):):)
I was able to modify, successfully, our 20120111 firmware release so that,
I could apply permissions and fingerprint tricks, com.google.android.maps.jar file,
remove some apps and add other ones.
The error in recovery mode, was due to a not correct signature...
pratically, we must always delete these files: CERT.RSA, CERT.SF, MANIFEST.MF
in: /META-INF
after that, we can make our changes (add or remove apps or other...)
I used Update.Zip Manager 3.0 (by Daneshm90), which is a script tool that permits to create
and modify update.zip files (it has many more functionalities that I haven't tested yet...).
It's necessary Java installed, on your PC: Download Free Java Software
Winrar or 7-zip, and Update.Zip Manager 3.0: http://dl.dropbox.com/u/14513610/Update-Zip-Packager.zip
I made a video of my testing: http://androidforums.com/4170661-post12.html
-Easy way to stream media from a PC to Geniatech ATV1000
Status
