PompeyFCUK
Samsung store out of stock
Anywhere you can buy a definite genuine battery for the Note4 ?
How AZ, I only buy genuine batteries, don't know why, just feels right for me. Phil
p.s. The OP is UK based anyway.
the 4 batteries I bought are all Samsung branded, for the same reason you said.
Hi, as I said if you check the feedback of the seller it will tell you all you need to know about if the things they sell are genuine, a few thousand people can't all be wrong. I have always had genuine batteries off the seller I buy from, and at a realistic price. PhilYes a bit steep but I'll pay little extra so I know it's 100% original. You might buy a good battery off other retailers but it's how long it lasts over it's course of deterioration.
