Genuine Swype kbrd for LG
cancega
I started my smart phone life with Samsung Android systems and became quite dependant on the Swype keyboard. I'm now using and LG G7 thinQ and the swype-like behavior of its supplied keyboard, as well as others that I've tried from the Play Store, are mediocre.
Is it possible to get the genuine Swype keyboard for my LG?
Thanks, but the links eventually come up as a dead end, however. The download from the nuance page is a link to Play and Amazon, neither of which have the product. :-(
You're right. Its 'support' link leads to a 'site not found' page. They're definitely the developers behind Swype, but it looks like they've abandoned it.
There are other contact methods, including phone numbers, on the site. Perhaps they can direct you...somewhere.
Edit: I found several versions of authentic Swype Keyboards on APKMirror. They're definitely from Nuance, the company that created it, and @mikedt linked to. Hopefully, one of those will work for you.
Edit: I found several versions of authentic Swype Keyboards on APKMirror. They're definitely from Nuance, the company that created it, and @mikedt linked to. Hopefully, one of those will work for you.[/QUOTE
