The option to change resolution should be accessible by tapping the cog wheel icon to access settings, then scroll down the list until you reach resolution. If it's greyed out it means that you have changed another setting where the resolution cannot be changed such as Panorama. If that is the case, then go through all your other options and change them back to defaults or whatever.
