Glass Screen Protector With Case - Help!
Hi,
I was planning on getting the urban armor gear case for my Samsung s4 at the same time I was planning to get a glass screen protector.
So, I was wondering if the Zagg Invisible shield glass screen protector would fit in the urban armor gear case.
Thanks!
Welcome to Android Forums Devillord234.:)
I think you will have more luck getting your question answered here in the Android Accessories forum.
I had no issues with Note 2 and S5 in UAG cases (my fav case) and tempered glass I used. But designs of glass screen protectors do vary where some have more margin from the edge and have it tapered down versus other ones that might not. For example, S5 tempered glass from Anker I reviewed worked great with UAG, Seidio, and Trident cases I reviewed, but not with half of Case-Mate cases where they pushed and lifted the glass edge.
I would suggest browsing S4 section Samsung Galaxy S4 - Android Forums and also posting your question in there as well. UAG is a popular case, and I'm sure others have it with tempered glass protectors they can share their experience about. Back in the days, Spigen used to be the king of the hill when it comes to tempered glass, but now you can get a lot of re-branded glass protectors for half of the price with the same high quality.
