Apps GLSurfaceView and other views in the same layout
Hi all,
I am trying to display a GLSurfaceView at the top of the screen with a separate layout containing buttons at the bottom. Seems simple enough, in fact I can get it to work with the button layout at the top and the GLSurfaceView layout at the bottom. But when I put the GLSurfaceView at the top, the button layout just doesn't show up.
Here is my main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical" android:layout_width="fill_parent"
    android:layout_height="fill_parent">
    <!-- View Container -->
        android:orientation="horizontal" android:layout_width="fill_parent"
        android:layout_height="wrap_content" android:layout_gravity="top" >
        <android.opengl.GLSurfaceView android:id="@+id/glSurface"
            android:layout_width="wrap_content" android:layout_height="wrap_content" />
    </LinearLayout>
    <!-- Controls Container -->
        android:orientation="horizontal" android:layout_width="wrap_content"
        android:layout_height="wrap_content" android:layout_gravity="bottom">
        <Button android:id="@+id/leftSignalButton" android:text="@+string/leftSignalButtonLabel"
            android:onClick="clickHandler" android:layout_width="wrap_content"
            android:layout_height="wrap_content" android:gravity="center" android:layout_gravity="left"/>
        <Button android:id="@+id/rightSignalButton" android:text="@+string/rightSignalButtonLabel"
            android:layout_height="wrap_content" android:gravity="center" android:layout_gravity="right"/>
    </LinearLayout>
</LinearLayout>
Here is my activity code
Code:
     public void onCreate(Bundle savedInstanceState)
        setContentView(R.layout.main);
        this.surfaceView = (GLSurfaceView) this.findViewById(R.id.glSurface);
        if (this.surfaceView != null)
            this.surfaceView.setRenderer(new DrawSomethingRenderer(this));
            this.surfaceView.setRenderMode(GLSurfaceView.RENDERMODE_CONTINUOUSLY);
Like I said, it draw the surfaceView just fine, but no buttons at the bottom.
Thanks in advance
raiderJerry
It is working now. I added an android:weight to each second level layout components and my buttons are now appearing at the bottom of the screen as expected.
Code:
        android:layout_weight=".9">
    </LinearLayout>
        android:layout_weight=".1">
        <Button android:id="@+id/leftButton" android:text="@+string/leftButtonLabel"
            android:layout_gravity="left" />
        <Button android:id="@+id/rightButton" android:text="@+string/rightButtonLabel"
            android:layout_gravity="right" />
    </LinearLayout>
</LinearLayout>
Thanks for all the help!
Raider
