Hello all,
I downloaded GO keyboard but there is a problem in switching between the input languages you choose.
For example, if I choose English and Spanish the only way you can switch between the 2 while typing is by pressing on the button with the language on it and then pressing the other language you want, unlike other keyboards where you just slide your finger over the current language and it switches to the other one.
Is there a way to change the way you switch languages there or I should download other keyboard you suggest?
Thanks!
Thanks!
