Go launcher ex help
mclark22
Hi, I have an htc desire and I just downloaded go launcher ex. While I love the design of the icons and the flow much better than the default home, I am having some difficulties. With the default home, certain applications came with their own widgets (such as evernote, pandora, etc), but I can't seem to access these widgets with go launcher ex. Are these features simply not supported, or am I just missing the steps to placing them on my screen? I really appreciate any advice or assistance! Thanks
Just so we're on the same track, do you know how to add widgets to screens in go launcher ex? If not, long press the screen until a menu pops up, from there you can select things like shortcuts, widgets and go widgets etc...
If they aren't appearing in that widgets section I can't guarantee this will fix it but now that you are using go launcher ex try uninstalling then reinstalling those apps to see if it picks up the widgets again. The only widgets I know that won't show in Go launcher are launcher specific widgets like the sense widgets.
I use Go Launcher EX also, and when I add widgets to the home screen, it's the same widgets I had when using the stock launcher.
On a home screen, long press, and then in the "Add to screen" menu that pops up, select "Widget". From here you can select any widget on your phone.
