Go Launcher & Widgetlocker help needed
melissapugs
I am slightly new to android, but really like Go Launcher. Today started widget locker: also cool. But the custom icons for the autumn theme go launcher don't seem to be available on the widget locker tool modes. I know, I'm being nit picky...anyone know where to locate the theme icon files in go launcher? Or, I am open to switching locker apps. Thanks for any help.
I have a same or similar problem.
I want ttoplace GO widgets on the Widgetlocker lock screen, but they are not listed when i long-press the lock screen and select WIDGETS.
This has something to do with GO widgets being listed separately on the GO launcher screens i suppose.
What i mean is a long press on a regular, GO launcher screen brings up the menu in which "widgets" and GO widgets are listed as two separate menu items.
Thanks.
I would think that the icons would be in the theme apks, the to get those on widget locker, you need to apk edit the apps you have installed and reinstall them.
What you're trying to do is basically trying to put a widget on a widget or one of your apps. In the same way you couldn't put a bookmarks widget on your clock, you can't add a widget to the locker.
I understsnd your frustration though, the only option really is to download some more themes from xda forums
