Go Launcher X drawer problem
kayteck
Hi everybody.
I have a problem with a drawer in Go Launcher X.
I have Samsung Galaxy Mini with v2.3.5 adroid and v3.05 Go Launcher X.
It works pretty smooth on it and I had no problems with it till yesterday.
I have all my apps set to folders in the drawer screen.
As standard I have 2GB SD card.
Yesterday my friend came and I've pulled out (unmounted first) my SD card and put his 8GB card into phone and installed MX Player on it.
After I swapped the cards back, most of the icons in the drawer were all over the place moved out of the folders (only the apps that were installed onto SD card are messed up).
Is there any way to put them back to folders (instead of obvious one - manually) or any way to prevent such messing in the future when swapping the cards?
Or is this a bug that should be fixed?
