objective: get Go SMS Pro to read the backup file it/i created.
I backed up my texts on my old phone (WHICH IS GONE NOW) through Go SMS pro's back up and restore system, but i backed it up to my computer because I though I'd be able to print them. It transferred onto the computer originally as a zip folder, so my hubby unzipped it and now it's an .XML file. long story short, I couldn't print them out and now I need them on my new phone.
What I've tried: Hooking the phone up to the computer and transferring the .XML file to the sd card under the following folders:
Gosms/backup/sms
SMSBackupandRESTORE (which i think is the original default messenger)
I have also transferred the file to the phone storage under the folders:
GOSMS
GOSMS/backup/SMS
GOSMS/backup/SMSrestore
I have also had my hubby zip the file back up and put the zipped version in all of those folders.
Now, after all of that when i open up the "restore" option in GOSMS it says "no backup".
I opened the messenger app (the default app the phone comes with) and went to "restore messages" which took me to a folder that I cant seem to find in the phone storage or my sd card (so i can't put my file in there), but it DOES let me "find" the folder that I want to open the file from and it will recognize only the .XML file but when I click on it it says "please wait" for a few sec and it appears to try to load, but then it says "unable to read file"
After all of my research trying to fix this, I know what I SHOULD have done, but bottom line is, I did it this way and my old phone is gone.
Is there any hope? Any suggestions?
Gosms/backup/sms
GOSMS
GOSMS/backup/SMS
