Go ThemesFactory beta2 (need help)
Lumabizz
Member
Have anybody used it and managed to export themes as .apk files?
I have downloaded the java, jdk and jre files that are required
to run the theme creator and export themes, and i have set the
jdk/jre bin files manualy to environment variable like the intructions says.
The theme creator itself works fine, the only issue i get is that i can't
export the themes to apk files, i get the following message when i try to export:
Make sure you have installed JDK and have set the jdk to environment variable?
It seems that many have had this issue, have any found a solution to this problem?
