going nuts
pulling my hair out
hello just picked up new android box a tx95plus the issue im having is that it only works for 5 to 10 minutes then it loses internet connection even though network setting says its connected,can anyone help with this issue btw i do have ipvanish thanks
same thing happens without ipvanish,when i go to kodi build system menu and look at network it reads busy,yet boc network settings say connected.i ve tried with ethernet and wifi hook up?
Have you tried restarting or resetting your router? But it could be a problem with the whatever it is streaming service itself. What about things like YouTube, do they cut-off?
Well whenever there's an odd problem that isn't making sense you should always start diagnosing things by restarting everything involved, and that includes the router. It's completely irrelevant that no other devices connected to it are working fine, there could be networking-related issue that's just between that TX95 Plus unit and your router. Restarting the router would at least minimize that issue as a possibility. (Your home LAN involves a lot of constant exchanges of traffic between your router and anything linked to it, even when you're not actively doing anything involving any of them.) If that same problem is still occurring after restarting your router and your TX95, at least now you know that it's something to look into and not just a one-off glitch.
That TX95 includes an Ethernet port doesn't it? Are you using WiFi or a cable to connect to your router? If a cable, have you tried a different cable? If WiFi, is it on a 2.4Ghz or a 5Ghz band connection and have you already tried switching from one to the other? Also involving WiFi, could range be a factor? Approximately how far away is the T95 from the router?
Have you tried turning all your wifi devices off and turning them back on one at the time, your new android box might been assigned the same IP address as another of your devices which is causing a conflict.
