Over at XDA-developers.com they have an entire section devoted to icons. We are not talking one or two pages,but hundreds. Try this address at the bottom, hopeful it will work. If not just cruise over to their website and do a search for Icons and you should be good from there. Hope that helps.
Cheers
Now a question. Im still trying to learn how to do all the different things.
Do you guys download them on your computer and then transfer to your phone? If so...what folder in your phone do you put them in? Im really trying to learn sd cards, folders and stuff..but its confusing as hell to me.
I download them to my computer first and then use dropbox to send them to my phone. Dropbox gives you like 2gb of storage so you can put fair amount of data there. I just move the files to my dropbox folder and it syncs it to my phone. From there I make a folder called "icons" so I know where it is. When you go to edit or replace icon just look for this folder...that is what I have done and it works.
Cheers
