Google Maps MyMaps problem
pauld197
Hi, I am a forum newbie so please excuse any poor etiquette.
I recently made a custom "MyMaps Google map with around 160 points on it, showing pubs in my local area. All works fine on a PC and on my Hero when using the browser, but when using the Google Maps app it misses off a whole chunk of points, probably about 30 points. I wonder whether it is a problem with the app or with Android 2.1 or with MyMaps or something else?
The map is shown at Pub Map - Heavy Woollen CAMRA with a link just below the map to display the pubs in a larger map. Using this link prompts me on the Hero to choose Internet or Google Maps to display the map.
Try not opening the map through a link.
I use My Maps without problem. The Map were created and saved by the same google account as I use on my phone.
Open Maps, go to Layers, choose More Layers, then choose My Maps.
Thanks for the suggestion. I tried that and it gives similar results - a number of points are missing, probably all in the top right corner of the target area. I just tried again and a different set of points is missing. I guess it is a bug in the Google Maps app? It is published as a Public Map, I wonder if you could try it?
Thanks
