Long story short. Google Maps navigation was working fine through my cars bluetooth for a while and now it is not. When I first noticed this, it was not the result of performing an OS upgrade or a system settings change from what I recall.
I can tell you that it is not a headunit problem. No changes have been made, plus phone calls and Tasker profiles (with AutoVoice) work just fine.
Also, I have "Play voice over Bluetooth" enabled in the Google Map settings.
Maybe the following will help you understand how it was working.....
You know how Tasker uses the call function (or in my case the System function) within tasks to play the audio? Basically the phone acts like t is on a call and when the message or call I get ends. the "call" drops. This is how Google Maps navigation worked for me.
Any suggestions would be greatly appreciated.
Thanks
Forgot to add...this has been going on for about a month. I currently have CM 12 5.11 nightly from 7/28 installed.
Murphy
Thanks
Murphy
