Outside without a data connection, I open Google Maps expecting to get current location using GPS satellites as source. I also have local maps cached. I confirm with GPS Test that I have good satellite lock (10 sats, 13' accuracy). But Google Maps tells me I have no data connectivity (as expected) but also continues to show Waiting for Location. And hitting the current location button has no effect other than generating the waiting message. I also confirmed that everything is enabled in Settings -> Location access. So Maps is not getting the data from the GPS. If I open Maps with GPS turned off, Maps tells me that is the case and will take me to Settings to enable it.
I have tried with Wifi & mobile network location both enabled and disabled. I also tried clearing cache & data and installing/reinstalling updates to no avail. Also loaded and used CoPilot USA to confirm that live mapping with other apps works under same conditions.
edit: JB 4.1.2 (don't know if it worked before)
