I read that some time ago GMaps introduced an option to set a "Voice Volume" level for the maps' voice guidance instructions.
I can't find them in mi GMaps ver. 9.10.1
Care to help me out? The voice level between GMaps and other media apps through BT is way off. Thks.
Tap on the Hamburger Bar then scroll down to and tap on Settings, Tap on Navigation Settings, Tap on Volume Level and choose from Normal, Softer, or Louder. HTH
As I said, the "Volume Level" option is not there. Check my screen capture.
This is an AT&T Galaxy S4 (SGH-I337) running Android 5.0.1 (latest available from AT&T) and Google Maps 9.10.1 (also the latest one)
It seems this is a long running issue in Android, I've found references to it dating back to 2012. There are a couple of tricks in that thread you can try. Damn Shame AT&T messed with your settings options like that. T-Mobile left them alone.
