My Google search widget is not working right. I removed battery and reset and that helped. But its acting up again. Do I have to keep removing battery to fix? Is there a permanent fix?
I'm having the same Issue. I've recently noticed that the search results would populate as I was typing. And now nothing. I've tried with the Android widget, and the HTC widget. How can I resolve?
Somewhere in the forums there's a similar topic w/ several people having this problem. Hopefully there will be a better fix other than reset every time. But I was seeing half letters in search bar which was annoying. In the meantime I ended up dumping the widget. Freed up space on home page and just use browser.
